Ok, so here's my setup: (I know it's not good, but i'm just getting into car audio)
Amp: 1000w Sony XPLOD (Rated Out: 185w x 2 (4ohms)) (Max output (1000w 2ohms))
Head Unit: Doesn't really matter, but I believe it's a Sony XPLOD head as well, ran me about $80.
Speakers: See below.
So heres the situation. I bought the above with 2 12in Sony XPLOD 400w speakers... not really knowing much about car audio.
I got a very nice vented box off ebay, and installed the 12's. All went well. Later that night I had it up rather loud, and smelt burning, later on they weren't working, just kind of scratchy vibrating as opposed to bumping. I would manually push on them and hear like a scratching noise. Could tell they had burnt up. (coil?)
anyhow, so both 12's were shot. Is this because the 1000w amp's gain (that little thing I can turn with a screw driver [is that gain?]) was turned up to high and they weren't high enough watt to handle it?
Now what i've done: I went and got a sony XPLOD 1200watt sub, 12in, and placed it in one side of my box, and left the other open for now. I plan on getting another 1200watt amp. My gain is down a little, it's not up all the way, about 3/4... and it's bumping pretty good. Can this sub handle the power better than the previous 2? It is alot heavier and looks like it's built alot stronger... plus cost about triple what the previous ones ($20) cost.
If I get another 1200w sub, have them both running on that 1000w amp, will that hurt anything or should I be good at that point? Wish I understood all this more haha.
Also, there's a little on off switch for depending on if you have 1 or 2 subs hooked to the amp. I had it on when I had the 2 12's that burned up, now I have it off for the 1 1200w sub, so I am using that right... for the record..
thanks for all thoughts. Sorry for the problems.
