Questions regarding wattage and such.
Yeah I did when I had the 2 12's that popped, but like I said, they were only 400watts. I didn't have it on when I only had 1 10in on there, and that burned up too.
I'm going to try and get better wire too, I'm currently probably using about 18g wire, and sounds like I should have 12-14g for woofers... then I'm going to get another 12 around 1200w, and keep my gain on my amp around 3/4 and keep my bass and treb at 0 on my head unit, and keep "loud" off.... hopefully that's the winning combination for now.
K. I watched the tutorial, looks like I need a multimeter as stated previously. I'll try and work on that.
So all my local walmart really carries is sony, but has a few jvc subs, and apparently has some pioneer subs, but haven't seen them in yet... and walmarts about the only place i can get audio shit (without going online)... so JVC or Pioneers better? They're both 12"'s, about the same price/wattage.
Also, Can I mix sub brands hooked up to my amp?
1. Good, do some research before you go ahead with this stuff
2. Don't buy your equipment from walmart
3. Don't mix sub brands
4. Pioneer > Sony
Okay, last questions...
I take it adding to the bass via the equalizer in my head unit, or turning on "loud" via my head units equalizer is a quick and easy way to blow my woofers?
also, does wire gauge affect the sound much?
Yes, its a good way to get a clipped signal, and you now know what clipping does.
Wire doesnt affect the sound at all, but how much current the wire can support. trying to push too much current through too small of wire causes it to heat up. Heat adds resistance as well as causes a fire hazard.
Look man, the volume on your H/U, turning the loud on, or adding an EQ to boost the bass, all boosts the signal going to the amp. The gain on the amp is meant to take that input signal and turn it into the rated output power. So if you set it with bass boost at 0, the gain will be higher than if you set it with bass boost at 10.
If you set your gains properly, but then go and crank the bass boost, the amp is going to be clipped. If you set your gains properly, there is NO way to get extra bass out without clipping the signal. Understand?
It's weird, my first amp was 95x4 for speakers and I had the gain at max and that didn't blow my speakers. Do some amps just have anti-clipping features, in which case that would be good to go with.
Well built speakers, or your input voltage was higher. Maybe you did damage them but dont know. I can clip a sub and have it still work. The VC might look toasty and the impedance is all off but it could still pysically move.
I know it was answered above, but what is the logic behind not mixing subwoofer brands? I mean, if they have the same wattage, and are in 1 box, is it still bad?
Syntax12
Syntax12
Internet
7ender
