Questions and concerns about build
Lschevelle
I was doing a dry build of sub enclosure yesterday and I decided to see how the kreg jig would work on some scraps. I wasn't able to find a bit long enough and small enough to pre drill and the wood split. My question is can I use"L" brackets instead and how good would they work? Second question what sealer to use? I'm not going to be able to seal the top panel because I will have to put my subs in when I put the front baffles on and I will not be able to get to the top inside corners what should I do?
you should be able to reach the inside of the panel from the speaker cut out. I use silicone to seal, now I'm using a black silicon b/c I find that it's easier to tell what spots I missed. the top or bottom should be the last piece of the assembly, that would allow you to easily get to the corners once the speaker hole is cut.
Lschevelle
Lschevelle
LA.
OmegaBunny
