q's on my sound system please help!!
  • 2
juvinile
i have a sony head deck and factory door speakers. i have the 2 twelves in a sealed box. i was wondering if any of u guys have any suggestions on how i can get my bass louder but still tight and punchy. the mtx amp is anly six hundre watts. i have it bridged at 4 ohm since i dont know if it handles 2 ohm bridged since it is a 2 channel. i had a bandpass but it wasint tight and punchy like sealed. i have a ported u think a should use that box instead of sealed. and if so u think if i get a 1200jbl amp it would sound louder but still be tight.
well if you did port it right it should give you around a +5db boost around the lower frequencys 50-100 but then it will slow down and match the graph of a sealed box typically i recomend using a ported box if you sub can handle the drop of pressure and because you dont hear in songs or with your ears usually below 40 hz and thats when sealed usually shines
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
892
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
4
813
thats good to hear that sub/amp is good pair, well one of the front speakers on right side, im guessing it blew out because its the one that makes...
5
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
juvinile
juvinile
chicago, il
dirkinthedark
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
