Protect mode only when driving
  • 5
jjkranz1
First post here hopefully you guys can help. I recently had my skar 1500 watt amp professionaly installed in a 2017 f150 but the amp goes into protection mode intermittently. Its weird because I used a DMM and appear to be at 14 volts when I am idling and I can't get the amp to go into protection mode. But once I get driving and play certain songs the bass hits will dim the headlights and the amp will go in and out of protection mode. I also have had the vehicles stock radio screen actually flicker off too. I'm assuming the stock electrical system just can't keep up? I would think when driving the alternator would produce more current no? I have yet to test the voltage while driving. If this is the case and the voltage is going too low would just a better battery help.or.should I do the big 3?
We get about one of these threads a day. Your stock alternator and wiring cannot handle the amperage draw.
Here is some napkin math:
1500Watts/14.0V = 107 Amps
Your F150 needs 80-100 amps to run all the onboard electrical/lights/computers/ignition. It probably has a 120-140 Amp alternator (depending on trim level/engine size) so I'm ballparking here.
Your Amp is drawing more current then your current electrical system can support. Fix it in this order:
1: Big 3 - https://www.acdcwireandsupply.com/BIG_3_POWER_WIRE_KIT_p/big3-1-0-kit.htm
2. HO Alternator - (I run a QuickStart Alternator but choose your own based on budget/Amperage, 200 Amp+ is what you want)
3. Additional Battery - This is last item usually in a build for someone who has so much power draw they can't keep up with an HO alternator. Battery acts as a load balancer but can and will burn up a stock alternator.
I really doubt your dropping voltage low enough to low voltage protect it. Especially if it doesn’t do it at idle. But you saying you had it installed at a shop I would take it back to them. You wouldn’t happen to have the Sony system would you?
Could be a lot of things like poor wiring thats grounding out somewhere with movements. Go back to the shop, take guy owner out for a drive and show him the issue and have him warranty the work without paying anything.
It's definitely low voltage because my head unit screen and the lit up buttons on my door for the power windows literally flicker off too?
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
Yeah i Yeah I know. I have my sub wired at 4ohm so I can get 300w rms from old amp. It’s 1000w max. And yes that’s the reason I got this pioneer...
40
4K
Your amp may have failed. A competent shop should be able to diagnose the issue in under 5 minutes either way. You didn't necessarily do...
jjkranz1
jjkranz1
Milwaukee
Slo_Ride
    Apr 26, 2024
    Apr 26, 2024
