Problem with my head unit. Popping sound...
  • 6
It does it on CD, Bluetooth, cable, SD card...
Try hitting the RESET button on the HU/Head Unit to see if that makes any changes first..Re-tune all your settings. You can use a tooth-pick or paper clip to hit the reset button. Hold down and count to 6-10 seconds and release to reset..with Power On
I couldnt tell or hear very well. You using a CD or USB or Btooth for the music?Or a cable from your Cell?
That popping you hear in the video is not the beat of the music, it's the popping I'm talking about. Notice when I turn the volume to zero it stops... Then starts again soon as I turn it back up. It also doesn't do it all the time. But always after 3-5 minutes of playing.
How old is the unit?did you buy it Brand new or used or did it come in the vehicle when you purchased the vehicle?
Check grounds real well. maybe even add a chassis ground if it doesn't have one already. And check the switched power lead wire for any issues.
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
821
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
636
Bburchett1
Bburchett1
Chaska, MN
Bburchett1
    May 12, 2024
Brendon Jenness
    May 11, 2024
