Problem with master and slave sundown amps
Hmm well I just went to look again but its to dark right now, I guess I'll have to mess with it tomorrow and go over all my wiring again. Anyways once I do want to connect all three amps, I am just going to run the rcas from the head unit into one amps inputs then another set of rcas from that amps output into the input of another, and do the same to the third correct?
Yup, just continue the rca signal to all the amps.
That should fix your problem
Yup, just continue the rca signal to all the amps.That should fix your problem
Alright, I mean one of the subs was moving good and the other wasnt hardly at all, then I just went out there and switched them and then the 2nd sub was movign good and the other wasnt very much. So maybe I just have something wired wrong that I didn't check
The "-" connections of the master should be hooked to the "-" connections of the slave.
The "+" connections of the master should get ONLY "+" speaker connections.
The "+" connections of the slave should get ONLY "-" speaker connections.
This is when strapped.
You cannot strap three amps together... so you will have to run them individually at that time.
same as the orion 1200d's iirc
46panel
46panel
Michigan
audioarsonal
BP1Fanatic
BP1Fanatic
