plugitin
She Bangs
they are not technically..but can be run at .5 ohm if you have good electrical to back it upI didn't think my saz-1500d was .5 stable either![]()
x2sundownz is the guy to talk toafter all, he builds em
what? just hook one amp to each sub then. You dont need to link themI just want one amp to each sub. If I need to get a maxxlink to do that then I guess I will do that.
True. So, I think the same may apply to strapped setups.they are not technically..but can be run at .5 ohm if you have good electrical to back it up
But, we must keep in mind that anything below factory specs daily will void warrantyTrue. So, I think the same may apply to strapped setups.And, if your running 2, soon to be 3 1500's, you have a good electrical setup
you have it wired wrong then...Well I just took out my three AQ 1200D's and exchanging them with the three sundowns. I want 1 amp on each sub at 1 ohm. But my problem is they are not puttin out the same output. One subwoofer is hardly moving.
Maybe you need a line driver to boost the output voltage of your huWell I just took out my three AQ 1200D's and exchanging them with the three sundowns. I want 1 amp on each sub at 1 ohm. But my problem is they are not puttin out the same output. One subwoofer is hardly moving.
eh, ive used 4 volt pre outs, 5 volts, and currently run an 8 volt out eclipse...not much difference if you set your amp up right...he has a nicer alpine so i dont think this would change anythingMaybe you need a line driver to boost the output voltage of your hu
True. Maybe 1 sub is out of phase?eh, ive used 4 volt pre outs, 5 volts, and currently run an 8 volt out eclipse...not much difference if you set your amp up right...he has a nicer alpine so i dont think this would change anything
