Problem with 12ga wire for sub...
microhaxo
Here is a pic of my problem. I just wired my sub 1 ohm with 12ga wire and i cant fit the wires from my box terminal in with them... Does anyone have a solution? I could solder on a piece of wire onto the two wires but that's sloppy.
If I ever have a situation like that, I just cut about half of the wire strands off of each side, then just twist them together and put them in the terminals(should be the same size as normal 12ga).
ya twist them together and try again.
x2.they will go with out cutting the wire if ur persistant enough.looks like the same terminals i have and my 12 gauge wire went in.it tried to give a little fuss,but i wasnt having it.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
microhaxo
microhaxo
MINNESOTA
AudioJunkie73
