No power to deck
Nozzie
I have a 2000 Saturn SL and i wired my new Pioneer deck in to my "92-up GM universal wiring harness." Now I have everything plugged in and wired but my deck doesnt receive power so it doesnt boot up. The only idea i have is its the wrong wiring harness but it fits just fine and should work. any ideas?
do u have a test light ? check the constant and ign to see if it lights up?
make sure u have a good ground.....
check fuses on radio and car for the radio....
make sure the antenna wire is on it..... sometimes that is a ground as well and wont work with out it.
how would i do all that Im pretty much a noob but im smart enough to figure wire to wire plug to plug lol
also the shop system still gets power
You don't need a light to check fuses. Just pull them out and see if they are burned out. The metal piece inside will be broken.
yep, i meant the light more just to make sure that the acc and the constant are correct.
start with ur fuses first then if they are all good then see if u can get ur hands on a test light.
to use the test light ground the part with the alligator clip and then put the part with the point on it to the yellow wire on your wire harness ( with the car off ) if it lights up then that is correct
to check the acc do the same as above but with the red wire and the key turned to the on position. if that lights up too then that is correct as well.
i believe this is the wiring to ur car :
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
now see if the yellow wire on ur aftermarket harness matches with the orange of the cars
and see if the red from ur aftermarket harness matches with the yellow of the cars.
Nozzie
Nozzie
Utah
sexyvic1
