Preamp voltage?
if the decks in question are relatively equal in options and in price go with the 5V
if they arent so equal its up to you to decide but keep in mind 5V is alot cleaner signal than 2V. cleaner is better
I could not tell the diff in my 8 volt Eclipse pre outs and my 2 volt Alpine preouts except I need to adjust my gains differently , The 8 volt actually made my amps sound worse , To much signal I think , Couldnt turn my amps down far enough , Thats what a gain adjustment is for !
Originally posted by shrinkydinx 8v? is that 'balanced'? are all amps compatible with 'balanced' preouts?
I'd have to agree.. most amps (that I've seen) only want at most 6 volt.. so 8 is more than they like and the gains won't let you drop far enough to keep the system balanced.. and I'd have to immagine that too much input voltage causes clipping much earlier in the amplifying process *shrug*..
Originally posted by Jmac That's unbalanced //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif It's 16 volts balanced //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You jerkin' chains here Macster? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Really, is 16 volts common for inputs on amps? I really did think it was pretty low for most amps..
Originally posted by Spddracer I could not tell the diff in my 8 volt Eclipse pre outs and my 2 volt Alpine preouts except I need to adjust my gains differently , The 8 volt actually made my amps sound worse , To much signal I think , Couldnt turn my amps down far enough , Thats what a gain adjustment is for !
their right most amps dont like voltages that high jls new amps with rips have a switch for high or low voltage selection
B&R Innovations
Kent State/Mentor Ohio
ryan_feine
michigan born
    May 14, 2026
michigan born
    May 14, 2026
