Power-crazy idiot!
  • 1
Chairchild
10
England
I have found some speakers that i have now bought for £500, and they will give out 5000 watts, but i cant find any amp which is powerfull enough. Is it possible to run three or more amps in parralell to give the required output? or will that screw it up in some way? any suggestions of powerfull amps will be welcome:)
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
387
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
646
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
468
Chairchild
Chairchild
England
Chairchild
winkychevelle
    May 24, 2024
