Poll: Which Sub For Better SQ?
The choice is always a matter of "best fit." Model them up and see which one gives you the best response, output, etc with the available power and desired box size.
To be completely honest... the Fi Q really doesn't sound that great to be honest with you.... WAY overrated.
Not REALLY loud like everyone says and not the most precise sub... I heard some Swiss Audio's that sounded better.
Universally good(quality, build, accuracy of output with minimal distortion) and a flavor of sound that suits your personal taste are two different things. Sometimes it's better to suit your personal tastes than to get the all-out best designed driver.
Yay at the Audiobahn reference(Swiss),
Fi Q works in a relatively small box, offers lots of excursion for sealed and gets low ported.
Polk Sr needs a relatively large box, has limited excursion to work with, gets very low ported, geared for lower power but similar sensitivity as the Fi so same output anyways.
Boston G5 again needs a somewhat large box, also has limited excursion, nearly identical low frequency response as the Fi Q, a little louder than the Fi off the same power(2dB), high qms which I'm a fan of.
Just from specs and modeling them up, I'd lean towards the Fi Q. There's more capability there, and you really don't gain much of anything with the other woofers. The Boston will be the most transparent/quick though if you're looking for the most musical.
MBrock4u
MBrock4u
Granite City, Illinois
Eugenics
