Please help with all possible outcomes and solutions
Ok, i have a problem with my amp going into protect mode if i hook up more than my 2 12s and i need to know what wiring method to use and what to hook up.... i have a 1200watt 4ohm bridgeable ssl amp, 2 300 rms max 4ohm dual 12s, 2 300 rms max 4ohm mtx audio 10s, and 2 300 rms max 4ohm kicker comp 10s. all speakers are SVC. how can i get the most with 4 subs?
So your running 2 diff branded 10's another diff branded 10's and same with 2 12's all in same vehicle?
This should make things intersting...
if you want to run your **** all ghetto like this its your business but heres how you can.
2 10s in series (8 ohm) in parallel with 1 12 (4 ohm) = 2.66 ohms take the 2 pairs of 2.66 ohm loads and wire them in series for a 5.32 ohm load to the amp and you will get about 80 percent of the amps capability the 12's will get more power than the 10's
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
955
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
danemd245
danemd245
Tennessee
hispls
    May 18, 2024
    May 16, 2024
