please help!! keep frying subs!
ok i just did exactly what yu said i turned my gain up until i lost cone control. so i turned it back down to the max without losing control. And i STILL could barely feel it in the car, and when i shut my trunk i could barely hear it..
Im pretty sure now its either my amp or the box. but the first speaker i fried worked great for three months in the SAME box. And it HOUNDED!! thinkin its my amp. but the amp still seems to work fine.. im about to just give this all up.
I have a video of all this if theres a way yu can see it.
ok i just did exactly what yu said i turned my gain up until i lost cone control. so i turned it back down to the max without losing control. And i STILL could barely feel it in the car, and when i shut my trunk i could barely hear it.. Im pretty sure now its either my amp or the box. but the first speaker i fried worked great for three months in the SAME box. And it HOUNDED!! thinkin its my amp. but the amp still seems to work fine.. im about to just give this all up.
I mean you can turn it up. its just not going to bed clean. that amp is only like 200 @4 ohm. yu can hear when they start to distort if you listen good./ampdouble check you settings on the CD player make sure the amp is hooked to the "subwoofer" channel on the pro-amp outputs. i mean your obviously clipping it to death so set it to where its decent until you get a better sub/amp
Budget will dictate everything
And you only need a shop if you can't read and take direction
You can make cheap stuff kinda loud but the sound you get will be distortion
Sounds like you want louder than the equipment you have will allow
What is all this installed in?
yea i dont have the plexi cover that came with it. does that make a difference?
---------- Post added at 02:44 PM ---------- Previous post was at 02:43 PM ----------
07 toyota camry
07 toyota camry
Yes that makes a difference. Like night n day. That enclosure is junk dude. Cover that hole with a piece of wood at least.
I doubt you'll do a proper custom ported box. Just get two jbl GT5 15s in a sealed box and toss it in your trunk, they should work with that kenwood amp.
Economical, simple and should bump a lot harder than what you have atm. Not to mention sounding way better vs your current box which sounds like a prefab bandpass box.
As a quick test, place the box so that the hole is against the floor of the truck so the hole is sealed off and see if it sounds different. My personal opinion is that the box is junk and is a large part of the problem and should be trashed.
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
levisrygley
nashville
ANTHONY.S1982
maylar
    Jun 2, 2024
    Jun 1, 2024
