placement of sub
.::DuD3::.
EE in training
if you had this trunk, where would you place a single sub? i'm going to fiberglass it, sealed, somewhere but i cant decide where. it cant be in the floor, because im doing a false floor there for the amps. any suggestions?
I found the most bass responce when my subs fire stright back at the back doors.
Not much from them firing towards me.
For a long time I drove around with my subs firing up. (as you see in my sig.)
I got a real good responce from them but...
when I turned them babies away from me (towards the back doors) ,
Oh my, it was amazing!
My friends swore I had a new amp.
Set-up is everything!!!
With one sub, it'll be different... But, I think you'll find the above will steer you in the right direction.
Slap together a cheap mdf box, and play with different placements.
Then go build that fiberglass box formed off the wheel hump.
You'll always know it's in the best place, for that sub, for that suv.
Just my 2 cents worth,
"B"
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Yes, time to move some stuff for sure. Have a little mini CA warehouse in the garage!
10
677
If not the kick panel, then I'd go dash Generally the farther away the better
Thank you. I’ll make pods for the doors. Next question, My back doors have no speakers. The rears are in the rear pillars. My front doors have 2...
The NVX linked to are very good subs. Way above factory grade for sure - even good OEM's won't compete. The frills are pretty stout and for most...
119
.::DuD3::.
EE in training
.::DuD3::.
Chesafreak, Va
ssj2xxgotenxx
