Pioneer Ported sub box problems
  • 5
The amp is capable of doing 500W RMS at 2 ohm but I will turn down the gains on the amp so I would get around 400W RMS. I played with some dimensions in WinIsd again and managed to get back down to 35Hz. Dimensions: 18.5"W *14.5"H * 17"D which equals to 1.98 cu ft. After port displacement and sub displacement I got 1.687 which I think is good enough??? Slot Port size is 13" * 1.5" * 22". For Rear Post velocity I got a peak of 93.6ft/s Peak. Will that be noticeable?
you wont have any port noise. 500 watts at 2 ohms is not what you will really see in real world numbers because of box/impedance rise. After box rise you will see closer to 4 to 6 ohms power wise so your actual ft/s is a lot less.
u basically gonna have my box just deeper not as wide., yeah wish u should be good on that sub., if u woulda got 1 like mine with little more power u be really happy, but the 3003 pro will work in that box when u don't if u ever upgrade the amp..
Hi Guys, thanks for your help all I finally got the hardest part of the build done //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. The only reson I didn`t got with the 3003 because it costed a little more. Today I designed my box in Sketchup I think it will turn out pretty good. I have attached some screenshots of the box maybe some one will find them helpful. When I build my box I will take some photos and post them her.
Thanks everyone //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yep looks just like my box with 1/2" wider port..
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
420
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
842
claytonc2001
claytonc2001
Malta
BOOMINGRANDPA
    May 24, 2024
