Pioneer h/u Sub level..
[quote name='sbcaprice305']Seems as though everyone has their opinion on what its best to set it at. Some say leave it @ 0, while other say +6 for max voltage.
Everyone except @wickedwitt feel free to answer. :)[/QUOTE]
I wouldn't recommend it, it will increase voltage, but distortion at the same time
I can't share my opinion, but I can copy what's correct.
[quote name='wickedwitt']Just got off the phone w/ a product specialist at Pioneer. 0 is "full output". +1~+6 is a boost introducing distortion.
@sbcaprice305[/QUOTE]
I want a recording of said conversation with the full name and birth date of the rep you spoke to.
P.s. I can't see the inserted image in post 5.
Stop failing. It was a cutout of the owner's manual for an 80-PRS. Its wording expresses that the Sub output is either an increase/decrease, meaning 0 would be full flat.
//content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
True, and why I state, all things considered equal. There are a multitude of variants, but that foundation is where you start and build from...
18
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
Download the manual. Should be some information provided. https://manualsfile.com/product/j0s9nlrgv.html
Sleeklsc
Sleeklsc
Sleeklsc
    May 12, 2024
Brendon Jenness
    May 11, 2024
