pics of sealed trunk ??
Hope that helps. I basically mounted the box on a platform I built, then built around it using the contours of the pass through then filled in the gaps with foam. Hope that helps.
this is what i have so far..do i just spray foam on the gaps? do i lay any tape or anything on box/car before i spray the foam?
spray foam = big *** mess
You can do mdf trim panels and duct tape. Might be louder not sealed off so I'd test both ways of numbers are your goal...
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
What would be your cost savings per unit having your coils wound in aluminum instead of copper? Can you quantify the efficiency (or dB) gains...
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
976
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
jasonjs
jasonjs
SoCal LA
bhsdriller
