pic of my groundpounder!!! 18 10's in trunk
that picture would work just fine if it didnt have the "kinda" part in it...
I kind of like the "kinda" part in there. That picture would definitely make me laugh with or without the text on it. I can imagine a situation where the cashier asks if he wants a bag and watching him staring blankly back at her for a few moments until he answers, "Yes, yes, I want a bag for my 10' PVC pipe." Then he calmly takes the bag and walks out. It plays out nicely in my head.
this project was not built for show or to put up high numbers. this is my budget groundpounder from ROE . I have LESS than a thousand dollars tied up in it total. So keep that in mind before you comment on the build. Did not make this thread to get props or critisized, just wanted to show the people how like to see and try somthing different. This setup moves a lot of air and pounds hard.
Cool. Any vids?
I'll make some this weekend. Did a little hair trick today at the shop with the front door open.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
all i have to say is................................
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif BAHAHAHAHAHAHAHAHAH //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
this is just at the setup with the two different subs tho. I think im gonna put 4 12's sealed in my sisters 2 door escort //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I'll start with something helpful first. The box build quality looks pretty good. And you should have used some yellow tops or other deep cycles instead of the redtops.
why not red tops that only coast me 25 bucks each from interstate batteries?
LOL //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
hay thats all i had to ride on for the weeken till my box was rebuilt. lol
If they were that cheap then no big deal but red tops are primarily used as under hood starting batteries. Yellow tops are deep cycles with much more capacity and able to handle the strain of an audio system better.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
726
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
slapmaster
slapmaster
mobile al
Pop da Hatch
    May 18, 2024
    May 16, 2024
