Peerless 6.4 mid/woofer
cal
Peerless 830875 6-1/2" Nomex Cone HDS Woofer
•Rubber surround
•Cast frame - truncated
•Ventilated raised spider
•Shorting rings
•182mm flange
•164mm truncated
•145mm cut out
•78mm depth
•75 watts rms
•4 ohm
The Madisound Speaker Store
USED . they have no rips, holes,damaged coils etc... one of the drivers the double sided tape got damaged,this is nothing see pic 1407
i bought these new and these were a special production in 4 ohms. part seen anywhere shows 8 but i assure you mine are 4 ohm drivers .
these sound amazing and midbass was unbeleavable. i had these running active 60 hz low end and 250 top end off a sundown 100.4 (unclipped clean power) no issues well with the drivers i just cant get them to work with my door skin on lol. mine was a 3way setup the drivers will play to 3k
100 shipped firm. these sell for 140 shipped
con u.s. only
cal
cal
cal
michigan born
    May 14, 2026
michigan born
    May 14, 2026
