Paintballers!!! Should I buy this modded gun? Also stupid question
Been going paintballing the last few weeks as they came up with a new 1/2 price monday at my local indoor place, and it would be worth it for me to get my own gun.
I found this one for sale, its for sale form a paintball place, they say its supposed to work fine but havent tested it and its sold as is. Its a tippman 98 I guess, with ak47 magazine, big barrell, looks like double trigger, spy anything else?
Just curious if this gun would be a good starter gun, my friends have spyders etc with high feet per second and hurt like a *****, but arent very accurate, I only need like 100ish feet accuracy, but Id like some power behind them. Does the tippman perform ok?
EDIT: Pretty much set of probably going to buy this tippman gun that I posted above, probably will get it for like $130ish I hope. ANy opinions on the 16" barrell and what it will do to performance? slow down balls? do they really go that straight with it? How to get ALOT of velocity out of the thing...
THANKS
paintball canisters used around 3000psi dont they?
If your using nitrogren or compreseed air they are between 3-5k. No that will not work with your average run of the mill compressor. And from the sounds of it your just using c02 and not nitro/hpa. Tippmanns are a good reliable starter gun as well. Just dont pay to much for it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Also, to fill our tank, I found this little valve, looks like it simply connects to my air compressor line, connect bottle to end, run air compressor and it fills up? Doesnt matter I just have a run of the mill air compressor that does 125psi? Itll fill the bottles up just fine?
THANKS
i lol'd....
compressed air is way better for your gun than co2
Ya just using standard compressed air, thats all we get at the field to.
Curious why it wont work with a standard "garage" compressor, looks like that is what it was design for, but theres no freakin info on it
And about the gun, could you compare say this tippman98 to a spyder or something, do certain gun shoots harder/faster in the sub $200 budget range
Hell I can find guns like this:
http://cgi.ebay.ca/Piranha-GTI-SEMI-AUTO-GUN-MARKER-PAINTBALL-PMI_W0QQitemZ130285523211QQihZ003QQcategoryZ47248QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Any good?
For like $75
http://cgi.ebay.ca/NEW-DIABLO-SLAYER-ELECTRO-MARKER-GUN-PAINTBALL-W-EYES_W0QQitemZ130294935823QQcmdZViewItemQQptZLH_DefaultDomain_2?hash=item130294935823&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A2|39%3A1|240%3A1318
For like $75
thats probably dookie^^
and it wont work because your "125 psi" cant fill up a 4500 psi tank..lolz
Well I figured this little valve would be doing the work and I wouldnt need a 3000+psi source
I think it may work though, I cant see them using that standard nipple fitting if it didnt? I'll have to research before I buy I guess
i lol'd....
Not gonna matter one bit in CA. The reason you cant use a normal compressor is like you said, its 125 psi. If your using nitro/hpa its at least 3k. 3k>125. And for all intents and purposes a pirhana is the the same mechanically as a spyder. No gun is going to shoot harder/further(besides a flatline barrel) than another.. you can adjust the velocity on every gun to make it shoot faster.
Well some gun to me OBIVOUSLY shoot faster/straighter than others straight out of the box.
Like is the tippman I pictured a descent gun that can be velocity adjusted on the fly from factory? never really held one before, let alone a modded one.
I get that my compressor is only 125 psi, and the tank needs 3000. But theres no way this little valve just pushes more and more and more air in there until you get desired pressure? I just dont get why a paintball place online would sell that if the typical guy couldnt use it. Just looks like what it was designed for to me
Ill have to grab some ebay links and post them up here for you guys to tell me if the gun are good or not. I just want a basic gun from this guy that will hurt my buds when I hit them and be RELIABLE lol
Like i said tippmans are a good reliable starter gun. You can adjust the velocity on them with an allen key on the left side. And once more there is NO way you you can fill anymore than 125 psi to your tank, im pretty sure that valve is meant for a scuba tank(3k psi) to fill your nitro tank.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Its says its for paintball tank refills though in the title and this quote in the link
"Stop paying those high prices at the paintball field for compressed air fills"
Pretty much all the info I can find on it, cant see the brand or find anything like it on the net
So that tippman probably wouldnt be to bad eh, I know you can mod them alot, but I never would, just want reliable welt giving power lol, any idea how much you can "adjust" the velocity on them?
I got a few good ones tonight, even a nice hump on my ballsack lol
WOT
Banned
WOT
Toronto,CANADA
Blue Fury
