PA system...
DiamondFanatic
Ok guys be patient with me because this is my first venture into speaker design/ outside of car audio. I felt like designing a PA system for my friends band, and this is kind of what I came up with:
Amp: Dayton PMA250
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=300-797
Woofers: Dayton RS180S-8's
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-364&dotd=101405
Tweeter: Horn
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=270-049
Now what I was thinking of doing is making two different cabinets, each with 2 7" drivers and one tweeter, and then building the amp in to one of the cabinets. I should be OK with one of those amps, correct? Any and all input is greatly appreciated, if I should go with larger drivers or whatever please let me know!
i'd use at least a 10 or 12 pro audio driver instead of those RS. it'll stab me in the heart everytime u play 'em //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
so even if they just want to use this for vocals and they already have amps for guitars and the bass, it still would be a bad idea to use those 7" drivers?
i wouldn't use them. remember, you are needing to make LOTS of sound, for LOTS of people. you need LOTS of displacement to do that. thus, there are 18" woofers and 12" mids for PA which you generally don't see in hifi setups. and the RS is too beautiful to throw in a cage anyway //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That's a good no non-sense design. Driver cost for that system is $200 per box.
The Dayton midrange idea is just too whimpy for a band, the vocals would
get drowned out pretty bad. Even that smithereen system would be barely
adequate if the guitar player likes to play loud and if the guitar player is using
more than a single 12", forget it, he's drown out the voice. Most bands lack vocal authority and get
drowned out by instruments. Ever been to a concert where you understood the
words sung? // hehehehe //
The NSB line array idea has interesting benefits for less driver cost but
involves more labor.
We already have one guy who compared the NSB array to the $2000 Bose PAS
system and they think it's an awsome alternative and the system was tested
live with great results => and he didn't even use a tweeter on the NSB array,
he did use an active crossover and EQ that was standard gear for this rig.
A two tower '8 driver NSB's array' stacked on top of each other is $24.
49 cent per driver + shipping = ~ $24 experiment. Get some cheap plywood
and make a small tower and if you don't like it, you didn't spend tons of cash on
it. Worse case, you can sell the system to another band and profit off the deal.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=269-570
Two stackable towers to make transportation easy, nobody wants to haul
around a single 16 driver tower so you make two 8 driver towers so they
fit in a truck.
SELENIUM WPU1209-SLF 12" PRO SOUND DRIVER
Sensitivity is 95dB.
Two tower 16 driver NSB array
8 ohm wiring = 98dB sensitivity.
2 ohm wiring = 104dB sensitivity
A tall line array loses less SPL over distance vs. the point source so
the NSB array will appear to be louder over a greater distance and it
will sound cleaner, an army of 16 4" drivers sound amazing, don't let the
small size fool you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's alot of work though to cut 16 holes and make the NSB's fit nice.
The line array idea has upgrade potential. Not loud enough? Spend another $24
to make another tower, spread them out or place them close to each other - a matrix array. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ,
add another 3dB to the sensitivity specs.
Cannibal Corpse inspires my speaker ideas.
http://www.cannibalcorpse.net/
What a sound system should do is akin to their song names;
An Experiment In Homicide
Relentless Beating
Shredded Humans
Put Them To Death
Scattered Remains, Splattered Brains
Bloody Chunks
Covered With Sores
Rancid Amputation
Innards Decay
Stripped, ***** And Strangled
Pulverized
Devoured By Vermin
Disfigured
Puncture Wound Massacre
Eaten From Inside
Savage Butchery
Dormant Bodies Bursting
Compelled to Lacerate
Hung and Bled
Mutation of the Cadaver
Frantic Disembowelment
.. and after there is Nothing left To Mutilate,
you Orgasm Through Torture
My audio recipe... sssshhhhhh....
//content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
... and do you know what is sick ? -> //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
I've been planning such a system for years //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif .. I'm still collecting drivers ... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
DiamondFanatic
DiamondFanatic
Oregon
thylantyr
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
