Opinions on Hifonics Brutus Class D Amps?
I like mine (1606d), overrated, like everyone said (the 1606d puts out about 1200-1300rms @1), but its still decent for the moneys.
I wish I would've spent the extra $30 and got the eD NINe.1, just so I can get another and strap it later on, when I upgrade. But thats about it, runs cool btw
haven't I read that you can daisy chain a bxi 1606? and other bxis? has anyone actually done this?
You can strap the bxi2606d only according to the owners manual. I have the Hifonics bxi1606d running a pair of RE SE10's and it kicks azz. Running One ohm and runs very cool. SQ isnt quite what my zapco 500.1 was but it still sounds great especially since I paid about a 1/3 the price of the zapco.//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Thinking the same thing you are. I'm running my 1606d on SE 12's, check sig
I run my 1206d at 1ohm and it stays totally cold. No heat at all. Seems extremely efficient, no light dimming at all on stock electrical. I set the gains @ 1000rms.
Good amps. Among the best cheap monoblocks today. A little overrated, build quality is not there, but very nicely engineered and that makes them pretty reliable.
my xx colossus took 1 ohm daily, rated at 2... stayed cold.
some of their products are nice.. some aren't.
I liked my older brutus 1500d amp just fine, done .5 for a long while but would go into protect if I pushed it hard.
anyone have experiance running the new bxi lines at .5ohm? im running mine at 1ohm and beats like a champ, but im thinkin of gettin new subs and itll be run at .5 ohm.
I have a BX1000D (1000w@1ohm), which is 3-5 years old? I don't remember... gets pretty **** hot, but probably cause I don't have it elevated off my box or anything. It went out once, but I think that was my fault. Runs pretty efficient - no light dimming at all at high volumes. After 3-4 years of still having it, that has to mean something...
1205D @ 2ohms....runs at cabin temp, gives my 12's all they can handle, then some.
the '08 Brutus amps are white, i like them vs the black ones, just buy from a dealer and get your warranty.
where do you guys need to generally have your level settings adjusted too ?
also bass EQ and subsonic/ high pass.
i have a 2600 RMS BXI and im looking for some opinions.
2 18''s in a ported box around 35-40hz.
Deck pre-out is only 2.2v though //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
mine ran really hot @ 1 ohm with gains under half...i didnt like it...couldnt compete with it getting too hot like that
if it got hot you have an electrical issue. i have installed hundreds and none ever got more than slightly warm unless there was a serious electrical issue.
with the hifonics MLX-100 you can strap any 2 identical mono block amps especially the brutus line. the 2600's dont require the box the rest of the brutus line does. the mlx 100 is about 80-100$
Pickzilla
Pickzilla
CT
Xprime4
