JL Audio 300/4 question
phish368
Please tell me if this makes sense for my connections.
I am using two JL Audio 300/4 amps to power 2 pairs of speakers. One amp for the front pair and one amp for the Rear pair. This question refers to one 300/4 amp powering the front speakers.
I am bridging each speaker on the 300/4. (left front on one channel and right front on the other channel)
I am splitting the stereo RCA cable with Y-adapters into each channel on the amp.
The question i have is, does the amp get set to 2ch or 4 ch input mode? I read the manual but I am still a little unsure if I should have it set to 2ch or 4ch.
Thanks!
Ditch the Y adapters, plug the RCA's into the front input section & set the input mode to 2 channels. The gains on the front input section will then adjust both sides together.
Or just run it like you are now with the input mode set to 4 channels. The separate gains will then adjust both sides separately.
However you do it, the RCA's should be connected to the front preouts of the deck.
phish368
phish368
Long Island, NY
KOL
