opinions needed
shake this
I have a friend that wants to wire up 8 6x9’s in a bus. Would it be better to get a 4 channel amp that is stable to 2ohms per channel and wire the speakers in parallel per each pair or go with a 2 channel amp and wire them in series parallel (4 speakers per channel) for a 4ohm load into 2 channels?
The 3 I've found that are 2ohm stable is the
RF P400-4
Alpine PDX-4
Kicker ZX 654.4
This is going into a party bus so we aren't looking for the greates sq, drunks just want it to be loud. LOL
didn't imagine you were after sq, lol. even so, i think the kicker zx 650.4 is going to be the best choice. it's the most flexible for install, durable, and plenty powerful. the p-400-4 might be close in power if it's about 4years old or more the pdx might be as powerful, if it's the pdx-4.150, but it has those stupid speaker connector plugs, which you might loose, or damage. and, should the party get roudy enough that the amp falls into great mishap, i would personally much rather see the kicker run through the bench, with the parts i probably have on hand anyways.
Yea I guess when I said 8 6x9's was the first indication that we weren't going for sq. LOL
I liked the layout of the kicker too but didn't know how well it would hold up. I don't understand why the HELL Alpine went with the speaker connectors for their amps.
True and still cheaper then running two 4 channel amps. I might tell him to quit trying to be cheap and just spend the money to have it done right the 1st time. The more I think about it, the more I'd like to run at least 100rms to each speaker.
shake this
shake this
Lubbock, TX
shake this
