One ohm or half ohm on my amplifier
common impedance rise if roughly 2x what its wired to.so if its wired to 1ohm look at the 2ohm power. probably around 3k
if its wired to .5ohm you are looking at getting the full 4500w out maybe a little more.
not that its going to be mind blowing but power is power and it does sound like you have stout electrical.
nice use of words *impedance rise.... saying box might ruffle some feathers
how you like the team?
Just like the mayhem, except louder on every note.
The low end is much much louder. I can play a lot lower too which is great.
I should have gotten a 15 instead of a 12 but I didn't want to sacrifice having a properly sized and ported box for more cone area.
But if you're looking for a team sub... this would be the one.
Why take the chance of something?? If it's not recommended but people are dumb enough to do it anyway....that's a 800 dollar amp. I myself would stay at the safe 1 ohm load.
It also lowers the amps efficiency and raises the current draw.
678
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
478
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
bigmak927
bigmak927
Detroit, MI
Papermaker85
