Update time:
Guys this is a prototype of upper line Class D monoblock. Keep in mind, its a PROTOTYPE, so please don't over analyze this thing down to a single cold solder joint. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Instead I hope you can get a feel for the direction we are going...
- Overbuilt Dual Unregulated Power Supplies
- Handwound Power Supply Transformers
- Big Nasty Power Supply FETs
- Isolated Pre-amp Section
- Aluminum shaft potentiometers
- Easy click settings for exact crossover settings
- Panel Mounted RCAs
- 1/0 to 4 Gauge Power Terminals
- All Monoblocks are 1 ohm stable and strappable
- Clip Indicators
- Audio Precision System Two Production Line testing
- Extruded Aluminum heatsink with Evenflow techonology
- Heatsink features 10g per mm of mass (most amps are 7g per mm)
- Integrated cooling via endcap vents
- Each amp is shipped in its own soft felt protective cover
