stilltippin863
what do i need to do??i got alot of poping and whining noise....even when my headlights come on it makes a weird sound....
i got stinger 1/0 ground from engine block to frame and front battery to frame...then from frnt battery to back battery then off the back batterys to the amps...you have a ground loop.
verify your grounds.
once i disconnect the rcas from the highs amp the nocise quitsWelp, you got a loop somewhere. You should first determine what is causing the noise. If I were you, I would start by disconnecting the rca's from the amps 1 by 1, and check to see if the noise persists after each one.
Does it quit only after all rca's are disconnected? If so I would try using a different pair of rca's to the amp to see if the rca's could just be bad. Just run them straight from the headunit, through the car, to the amp to find out. Also check your head unit grounding location while it's out.
Noises like this can be a pain //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
on a board in trunk...Does it quit only after all rca's are disconnected? If so I would try using a different pair of rca's to the amp to see if the rca's could just be bad. Just run them straight from the headunit, through the car, to the amp to find out. Also check your head unit grounding location while it's out.
Also, where is the amp mounted? I've seen noises like this occur because of mounting with screws into the chassis.
kool i do not think it is in the wiring harness i think it is direct but i will go check...if you're using the factory ground in the wiring harness, get rid of it and ground directly. If it doesn't eliminate the noise entirely, I can almost guarantee it will help atleast somewhat.
well that looks like what i am gunna have to have....i grounded the head unit by it self...then ground it through the factory harness...does the same thing...so now i got to get a ground loop isolaor...sure thing.
if everything fails, you could always use a ground loop isolator, but lets save that as a last resort //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
