helotaxi
Kilroy was Here
Agreed.alrighty then, but if the car burns down, it goes without saying "I told you so"
I got the dude runnin' two seperate runs....lol I said **** it...one run of 4 awg and one of 1/0 awg
You can do both...that and the body as ground also. Never hurts to have extra ground. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifthanks alot tuan for recieving my message and responding here. That really helped alot.
Cya @ garden grove.
and also, i didnt know it's ok to have a long *** 1/0 negative wire from battery to all the way to the back. i thought it was bad.
-dante
That's my school of thinking.i'm going to go with helotaxi on this one. Table at:
http://www.interfacebus.com/Copper_Wire_AWG_SIze.html
Shows 4AWG wire @ 41738 circular mils. (the table is entirely based on 'VERY LONG RUNS' of 4ga...read the notes at the bottom to see the math).
Good 4ga can be thicker in some cases, shitty 4ga may not be up to spec. Voltage drop at 300 amps on 'short wire runs' is less than .2v. (under 2%). You'll lose more voltage than that by using a distro block instead of a solid wire run.
Using 200 circular mils per ampere (as instructed for 'short wire runs') as a gauge, you get over 200a continuous current carrying capability on 4ga wire. I challenge you to pull 200a+ continuously to that amplifier while sitting in the vehicle for more than...uh...2 minutes straight. With music. Good luck!
YMMV.
you were doin good on everything till you hit this brick wall....always ALWAYS ground to the frame, unless body panel is the only option, a true good ground is directly to bare metal frame.You can do both...that and the body as ground also. Never hurts to have extra ground. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
YMMV.
Only trucks and SUVs have frames anymore. For cars, it's all just sheetmetal. That's why I'm a big proponent of grounding back to the battery in just about every situation.you were doin good on everything till you hit this brick wall....always ALWAYS ground to the frame, unless body panel is the only option, a true good ground is directly to bare metal frame.
Metal has a resistance value...resistance is what causes voltage loss and heat buildup (watts lost to resistance = heat). Voltage doesn't really cause heating; amps do. When you push amperes (a measurement of electricity) through a wire, the wire's resistance increases. As the resistance increases, more power is lost to heat. The wire heats up. The insulation melts. Shit catches on fire. Thicker wire has less resistance than thin wire. Short wires have less resistance than long wires. A length of 4AWG that is 2 feet long.... well, see my previous post.i don't get it. im lost? i guess it's cuz i just got home from work? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I don't own a vehicle with a frame.you were doin good on everything till you hit this brick wall....always ALWAYS ground to the frame, unless body panel is the only option, a true good ground is directly to bare metal frame.
