Ohms question
  • 4
brennen232
i am currently running 4x6s in the front of my vehicle and 6x9s in the rear , the 4x6s are 2 ohm svc and 6x9s are 4 ohm svc , both sets are begin run off a kickerzx350.4 which puts out 60rms x4 at 4 ohms and 90rms x4 at 2 , each speaker is running off a seperate channel , my question is that since the 4x6s are 2 ohm and 6x9s are 4 ohms is that causing any problems for the speakers or amps since the speakers are different ohms ?
As long as your amp is 2Ω stereo capable there won't be an issue. As mentioned, your 4x6's will just be getting more power unless you turn your gains down.
^^^^ The amplifier will also run a little hotter @2ohms also,but it should be just fine.
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
It also depends on how many subs you want to run and what Ohm value they are.You can run a singe sub, 2 subs, 3, or 4 and so on. This is a good...
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
brennen232
brennen232
gobles, MI
audiobaun
    May 31, 2024
    May 24, 2024
