Odd issue with amp...repair?
  • 1
Sguirrelfeather
I have a JBL GTO-5EZ amp (5 channel) which has the front left speakers randomly increasing in volume by a large percentage....so much that it drowns out the right speakers. I verified it was the amp by swapping outputs and then it only did it on the other side. It happens so randomly that I can't figure out if there was a loose wire, etc, so figure it's got to be something internal. I guess my question is, who do I contact to see about getting this fixed who is reliable and won't cost me an arm and a leg? I intend to replace it in the future with a dedicated 4ch amp since I now have a dedicated mono-block for the sub, but in the meantime I still need it.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
It sounds like the remote is wired to the interior courtesy lights. Those lights come on as soon as you remove the key from the ignition. Try...
They managed to turn Covid into a wedge issue.
Sguirrelfeather
Sguirrelfeather
Mountain Home, ID
Sguirrelfeather
    May 18, 2024
    May 16, 2024
