Not a noob with a noob question
Hey folks, I have done instals many times, however, I need some help. I was given a head unit from a friend and the wiring diagram has me a little stumped. I think its from overseas. I will attach a picture of it, View attachment 26552443
#4 sw key 1
#5 brake
#14 sw key 2
#16 Black
These are the ones that have me confused.
Any help will be appreciated
Pretty sure that pink one has something to do with the parking brake. Not sure about the rest
#4 sw key 1
#5 brake
#14 sw key 2
#16 Black
I think that might be a 7 speaker hu. because it has 2 sets of rear outputs, those sw keys might be for a stock sub
I was thinking SW KEY 1 is the key (ignition) ACCESSORY position and SW Key 2 is the key (ignition) ON position, but I really have no idea.
I was thinking SW = SWitch, and KEY = ignition key.
Sw is steering wheel. That makes sense now. I always figured sw would be switch. Ok, so that's figured out. Anyone have a clue about pin 16? Black (brown). Is it possible that 16 is the head unit ground because pin 1 says sw key ground.
it says back, not black?
id bet that 1 is primary Gnd, 6 and 11 go to battery. also, you may be able to ground pin 5 right to the head unit to avoid video saftey feature. some HU do need a relay though, although i haven't installed one yet
Ah back up camera, duh, but a back up camera has rca composite plug plus a hot and ground. Yes, the pink can be ground to override the safety feature so video can play while moving. if im not mistaken, #6 is a ignition switch lead (off when key is off) and #11 is constant hot
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
If I was set on using what you have: I would get a head unit that will play 40-50w RMS x 4. Use that for your 3.5s and 4 x 10s, or get a small...
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Bc_Rigger
Bc_Rigger
Jackson, Ms
Bc_Rigger
