I hadn't considered the Mosconi. I like that it's output voltage reaches 8 volts. How does it's software compare to the Helix DSP?The Arcs software is always getting updates. They are not user friendly. Helix and Mosconi is easy. JLs upcoming Twk looks nice also. Audison if you want to run optical to Audison Voce or higher amps.
Many great options out there. The DSP market has nutthuggerey like the bass market or worse
Helix is the leader right nowI hadn't considered the Mosconi. I like that it's output voltage reaches 8 volts. How does it's software compare to the Helix DSP?
so let me get this right helix has the best processor but you cant hear the difference from a cheap class d as compared to decent class AB?Helix is the leader right now
You don't understand processors do you?so let me get this right helix has the best processor but you cant hear the difference from a cheap class d as compared to decent class AB?
You don't understand electronics in general?You don't understand processors do you?
Ok I'll make you look stupid againYou don't understand electronics in general?
well first off the bet ten is fine its more than capable. if your comparing simply the software ease of use and correlating to better or worse i disagree. The tuning options on both units are more than enough if you properly install the speakers. i've heard some of the best sounding cars that used little sound processing. simply by using the correct drivers, axis, placement, power and simple techniques like eliminating comb filtering naturally with driver placement, selection, ideal enclosure and using the drivers natural rolloff to complement the cutoff instead of destroying phase and dampening by just selecting drivers and implementing the xover points decided buy altering slope and Q to try to correct phase issues then having to readjust TA etc.. don't get me wrong when you face challenges of drop speakers in stock locations in leaky doors etc yea having a ton of options is nice. but simply building a proper enclosre for hte midbass and midrange goes a LONG way. the correct axis and height etc is MUCH more effective then 1000 tuning options.The software is better in the Helix. The Audison is getting old. I had the Bit 1 in the last car. The Audison can wipe out the stock EQ but only at the set volume.
The helix can run a center channel.
The software makes the tune. If it's to complicated the tune won't be good. If it's to limited the tune won't be as good as it could be
Every DSP has high level inputs BTW
Why would I listen to somebody that's clueless when you are talking stupid to somebody that's used DSPs for years?
So you want to spend hours installing than run the RTA or just hear the cars interior destroying the responce?well first off the bet ten is fine its more than capable. if your comparing simply the software ease of use and correlating to better or worse i disagree. The tuning options on both units are more than enough if you properly install the speakers. i've hear some of the best sounding cars that used little sound processing. simply by using the correct drivers, axis, placement, power and simple techniques like eliminating comb filtering naturally with drver placement selection and using the drivers natural rolloff to complement the cutoff instead of destroying phase and dampening by just selecting drivers and implementing the xover points decided buy altering slope and Q to try to correct phase issues then having to readjust TA etc.. don't get me wrong when you face challenges of drop speakers in stock locations in leaky doors etc yea having a ton of options is nice. but simply building a proper enclosre for hte midbass and midrange goes a LONG way. the correct axis and height etc is MUCH more effective then 1000 tuning options.
