Disable HPF Pioneer AVH-5800bhs?
reset the unit.
I tried that and switched from using network mode to standard mode. Standard mode only has a hpf filter for fronts and rears, thankfully I can turns these off. I was concerned using it because the manual says this mode may damage speakers. I think they say that because it is intended for passive speakers with built in crossovers and if used in an active situation, without proper hpf/lpf filters speakers can be damaged...I 'm thinking I interpreted that right.
Since I'm going active and using the crossovers on the DSP I should be ok.
We'll see
Landshark77
Ft. Lauderdale, Fl
Landshark77
