Noise ***** help me get rid of it plz.
Originally posted by crispy highs Well I guess that's another good thing to know........//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
it will always be easier to generate a voltage across a HIGH reststance circuit than a shorted one
with unplugged RCAs you could be fooled into thinking the noise is comming right out of your amp--------------------if any magnetic field are near your open inputs
The Same thing happene to me check to see if your car has a pre out for a amp somtimes the factory deck is able to be used with a amp and there is a pre out to fix mine which was making the sound becauae the while rca hookup was hitting metel we just put some electical tape on the female rca conecters and it was fine
Ok I made some muting plugs and checked the high amp tonight and Im still getting the noise from my comps....so...what do I need to check now? Please any ideas...
Night Pirate
Originally posted by Night Pirate Ok I made some muting plugs and checked the high amp tonight and Im still getting the noise from my comps....so...what do I need to check now? Please any ideas...
Night Pirate
it didn't mute?
that leaves the amp
speaker wires
any passive x-overs
the speakers
remove the speaker wire from the amp while MUTING-------- using a small test speaker connect it to the amp. did it shut up?
if no-------- get a new amp
if yes ----- look down stream of the amp to see where the noise is coming from.
test resistance of the comps------ should be the same for both
test resistance to ground from the speaker wires----- should be off the scale
if these check out do this
look to see if moving speaker wires/passives/speakers ----- makes a change in the loudness of the whine
Got the noise in the test speaker too //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I have one of my older amps so I hooked it up in place of the noisy one and It was silent. Crazy stuff.... amps just a couple of months old and has been doing this since I installed it. Strange that the noise goes away when I disconnect the sub amps or turn the engine off //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Anyways I bought the amp from the Zeb and hopefully there custumer service is good for this. I wonder if they will try to rapair the amp or just exchange it (which I would perfer) because its a strange problem and if you just use this amp and no sub amp you don't get the noise so I want them not to think its working fine when it isn't.
chris229 I appreciate all your tips and suggustions on what to test....Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Night Pirate
A friend of mine had an issue with noise and whinning on an amplifier in his SQ truck. He was using a Gladen 2 ch. We tried about 5 of my...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Night Pirate
Night Pirate
Cali
Night Pirate
