Newbie port question
Loud01Blazer
150+ for 2009??
Ok i'm a little confused. My box will be 24Hx24Dx37W. The port is going to be along the bottom of the box 5"Hx30"W i want it to be tuned to 33hz. Carstereo.com tells me if it's a "square port" my length needs to be 27.09" but if i check yes where it says "Is this a slot port?" my length changes to 12.09" which is a BIG difference from 27". Which one of these is accurate? After looking at this i NEED input before i build this //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
do that math each 6" aero is 28.26 of area
with aeros you can get away with half of the area it would need if u were doing slot port
12-16inches per cube for porting with aeros you can get away with half that so 6-8inches per cube
wat size subs and how many, and wat size box
To get 150 sq inches of port area you'll need (5-6) 6" aero's...5 will be a bit under 150 sq inches...6 will be a bit over. 150(desired port area) /28.2735 (area of each 6" port)=5.305 (ports you'll need)...
If you're going with (5) 6" aero's you'll need to make each port 30.6" long to be at 33Hz tuning
And if you're going with (6) 6" aero's you'll need to make each port 37.59" to be at 33Hz tuning
Good Luck //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Loud01Blazer
150+ for 2009??
Loud01Blazer
Hamilton, Ohio
king ranch
