Newbie needs sub selection help
I'd see if i could find A JL w6 for a good deal. They are made for small sealed enclosures and 600rms would be perfect.
Just as a reference I found a w7 for 250 today on CL
and a w6 in a box with kicker amp for 300 on CL as well.
So theyre out there. Just search around! But itll be your best bet for your space and amp. IMO
I know someone will have something to say though.
I am no starting to kick around the idea of a 10" since I can fit a nice one in the size I was looking at as mast240 mentioned. What are the thoughs for a 50/50 mix of heavy rock/rap. Heck, what about a 8" like the sundown sa-8??
the subs displacement is normally listed by the manufacturer.... but you also want to take into account the wood itself... if you use 3/4" mdf, which is most common, then your actuall goin to lose 1.5" of airspace for each dimension... (i.e if your box is 12" wide... you only have 10.5" of actual airspace, if that makes sense)
ah, ok yes it does. Once agin thank for you help!
So if I can make this work do you think this is the sub for me? As princ stated the jl w6 seems to be exactly what im looking. Is this the best comprable for the situation ($, wattage, space) I am in?
You could get two 12" alpine type r's with a box for 200-250 of off craigslist. They sound really good, and handle the lows pretty good. I had a pair and loved them. You could always get 10" idk tho if they make them. They are 500-650 rms each. MTX sounds good also, a buddy of mine has just one in a 05 forester and it shakes the car like crazy.
feiticiera
feiticiera
Buffalo, NY
USAFbro
