Newbie here - wanting suggestions/opinions/thoughts
hawki
So, car audio is not my specialty, so i am hoping to get some opinions on the best setup i should go for for my deck/car.
I own a 2010 Prius, and just had a Kenwood DNX9960 installed that replaced my OEM nav system that came with the car.
My Prius has 8 speakers - and im looking to replace them as the bass isnt quite qhat i'd like, nor is the overall sound. The speaker specs for my car are:
Location Speaker Type Quantity Size Impedance Rated Input Power
*1 Front Squawker 2 65 mm (2.6 in.) 2 Ω 20 W
*2 Front Woofer 2 150 mm x 230 mm (6.0 in. x 9.0 in.) 1.8 Ω 28 W
*3 Rear Squawker 2 65 mm (2.6 in.) 2 Ω 20 W
*4 Rear Speaker 2 170 mm (6.7 in.) 1.85 Ω 40 W
Location 1 is up on the dash near each bottom corner of the windshield. Note, this is a 2.5" sqawker (upper midrange per definition).
Location 2 is in the front door. Note, these are 6x9 speakers. I suspect 28W is a typo and would be more inclined to believe 40W.
Location 3 is up on the rear door sill just behind the driver's seat. This is a 2.5" tweeter.
Location 4 is the lower rear door. Note, this is a 6.5" speaker.
DNX9960 specs are:
Audio
- Maximum Power 50Wx4
- Full Bandwidth Power 22Wx4
- Preout Level(V) 5.0V @ 80 Ohms
- Preout Impedance(Ω) Under 80Ω
- Speaker Impedance(Ω) 4-8Ω
So, I am wondering what would be some good setup and equipment ment to make this sound really good. From crossovers/ammps/speaker replacement and even a sub (preferable thin/bazooka or something along those lines) The sub isnt nessesary is the speakers themselves suggested was give reasonable bass, but i am upen to a sub.
ANY HELP/SUGGESTIONS would be huige as again, right now im at the mercy of salesmen.....
Thanks in advance!
interesting project.
i own a 2002 Camry and it has 2" mid/tweeters in the dash and 6x9 woofers in teh doors and rear deck.
i'm looking at Madisound.com for a nice 2"-2.5" midrange driver so i maintain a good sound stage height. I'll build custom crossovers for whatever I do, if i don't go active. I was looking at the Peerless drivers specifically - paying close attention to frequency response on- and off-axis.
The Madisound Store
Door woofers - Parts Express sells a TangBand 6x9 subwoofer that is very shallow.
Tang Band W69-1436 6"x9" Neo Subwoofer | subwoofer 6"x9" subwoofer neodynium subwoofer tangband tb speakers ccflippy | Parts-Express.com
The easiest recommendation is to just buy two 6.5" components sets and a sub and call it a day. just watch your available speaker depth and build baffles to accomodate the different driver sizes.
however, i believe there is a distinct advantage to maintaining the midrange content at the dash.
hawki
hawki
Vancouver
keep_hope_alive
