Newbie Help PLZ!!!!!!!!!!!
alotofbang
Ok i finished my first install a couple weeks ago with 2 kicker comps 15" and a hifonics BXI 1208D i have them parallel for a 2ohm load the amp is suppose to be putting out around 900 x 1 I know its probably going to be a little lower but it seems like they are still underpowered how can i Check if they are.
it ist possibly to wire to 4hom subs to 1 ohm bt how can i check if my amp is being underpowered
1st) No..
2nd) Not sure what You mean Amp underpowered? you mean not receiving enough current? What gauge are you running. Should be at least 4awg for power & ground. May not need to but never hurts to do Big 3. As for the woofers being under powered you should be cool. That amp makes enough power to push them pretty good @ 2ohms.
alotofbang
alotofbang
denton, texas
EL Diablo X
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
