new system
plus if i only get two i can only run that amp at a 2 ohm or .5 ohm load and i dont even know weather or not these amps are stable at half an ohm...with 3 and i can it at a 1.34 ohm
when the AQ's are stable at 1 ohm but im not shere about .5 ohms. 1.34 should be fine. what kinda car u got. cuz your box might be to big for it. id do 2 15's or 2 12's if i was you.
get 2 12's or 15's or 18's if you have the space and run each off an AQ 2200 at 1 ohm a piece. You would achieve this with 2 D2 ohm subs. I am going to run 2 18's with a 2200 on each but if you do not have the space run 12's or 15's but a 2200 on each sub is plenty for daily
ok so i guess i will try 2 hdc3 12s and two aq 2200s... i currently have one 9515 and a aq 2200 its loud but i want louder....what type box should i do woofers up port back.....and what should i tune it to...
tapout383
Just boughta Zone.
tapout383
Virginia
schrummy
