New System, HELP!!!
justboughtaz
Hey guys, i'm in the process of building a new system for my Z and need all the input I can get since I have no prior experience with the acoustics of the Z. My last systems was composed primarily of Kicker so i'm thinking of sticking with them for the amps. Below is what I have this far:
Pioneer AVIC Z120BT Head Unit
(2) Orion HCCA 10.2 Subwoofers
What door speakers, behind seat speakers do you recommend?
What amp would you recommend for the two orion 10" subwoofers.
I am not trying to go overboard on the amps, I have priced the following and would like to stay in the range of $1000 for amps.
Kicker ZX2500.1 (10ZX2500.1) $679
Kicker ZX350.4 (10ZX350.4) $169
I plan to run the two subs @ two ohms, and the kicker amp is rated at 2500 watts RMS @ 2 ohms.
Thanks people
Just a quick glance at the specs tells me that the HCCA 10.2 can handle 1500 watts rms... The amp you suggest only puts out 870 @ 2 ohms, 1200 @ 1. Seems to be somewhat less expensive than the kicker, but kicker will do 2500 @ 2 ohms, which I would expect to be more stable. Just my 2 cents, maybe you can explain.
510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
510X1 @ 4 ohm,
870X1 @ 2 ohm,
1200X1 @1 ohm
its not always about what the specs say, i would take that audioque over the kicker any day. The power is cleaner and im sure the AQ can do more than what its rated
I see, well... This seems more like it Audioque: Amps: AQ3500D.1 Seems that this guy has much more configuration settings.
Specifications
Model AQ3500D.1
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Remote Gain Control yes
Clipping Display Led yes
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V @ 1% THD 5300W x 1
1 ohm Power @ 18V @ 1% THD 6000W x 1
1 ohm Power @ 18V @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Guage x 2
@PlugItIn, yes sir, you are correct. I do not plan to do this installation myself. In order to save bucks on the system, I decided to purchase all of the components myself, and shop around for the best install deal. At that point I will have a custom box installed and extra batteries added, as per the installers reccomendation. I know how these guys overprice their hardware, so I decided to cut that profit out of the sale.
justboughtaz
justboughtaz
Phoenix, AZ
Bob Saget
