new set up advice
installing in a 2002 Chrysler 300m special
ok heres what I have..i know some wil say get this or that but its what I have
head unit Kenwood KDC-bt848u
5 ch amp..old school Soundstream Tarantula 800/5
Power Rating - 4 x 50W RMS (Stereo) - 2 x 200w (Bridged), 2 x 200W RMS (Stereo) - 1 x 400W RMS (Bridged)
Frequency Range - 10 Hz - 50 KHz
THD -
S/N Ratio - > 115dB
Input Sensitivity - 150mV - 12V RMS
Load Impedance (Stereo) - 2-8 Ohms
Load Impedance (Bridged) - 4-8 Ohms
Damping Factor - > 500
Slew Rate - > 50V/us
4 Kenwood 6993 PS..going on my rear deck
Highlights:
•5-way 6"x9" speakers (pair) 4 ohm
•Diamond Array Pattern polypropylene woofer
•rubber surround
•2-3/4" water-resistant paper cone mid, 1-3/16" PET balanced dome tweeter, 1/2" PET dome supertweeter, 1/2" ceramic supertweeter
•power range: 2-120 watts RMS (500 watts peak power)
•frequency response: 66-22,000 Hz
•sensitivity: 89 dB
•depth: 3-1/16"
also 2 Kenwood for front door speakers
+2 bazooka tubes 8"
now will i need a 2ch amp for the bazookas and let the tarantula power the 4 speakes?
will i need a capacitor or extra battery? amp has built in crossover i believe for low high and mids
will this affect alternator?
thanks for your time guys
those rear speakers are a very poor choice.
You will not need a capacitor as they do not do anything to strenghten your electrical
Yes you need an amp for the 2 - 8" subs
You plan on mounting them in the trunk? How do you plan on getting the bass into the car?
Why do you want to run 4 - horrible shrill 6x9's in your rear deck?
When you go to a concert do you turn away from the stage to listen to the music?
Why do you want more sound behind you rather than in front of you?
thanks crispin..i guess ill just put 2 6x9 and the bazookas in trunk..no room in car for bazooka so only place is trunk,,in front door im puting 6.5's. btw in the trunk im putting against the backseat so that should do it unless you recommend something else?
i thought they were good 6x9 since they are 5 way
i've done a couple cars like yours in the past .you prolly wont hear the bass from the tubes , if anything take the woofers out of the tubes and build a box for them ,you'll get better output and response from the box,better yet get some 12s or 15s for the trunk and at least 1000 watts rms
What's wrong with your factory headunit?
The setup is cool.
Dont over due the rear deck speakers &put the 8s in whatever they like and you should be good.
boricuadon
boricuadon
New York City
LosIsATool
