new ported box
  • 6
sealed box is not for me im going ported for the new type r´s (2 12")
is this going to sound good, hit hard and low?
single 3cuft box, single slot ported tone to 34hz
its going to make any port noise?
Port Width 3"
Port Height 15.7"
Port Length 31"
im thinking about cutting some pvc pipe to make the inside coner´s of the box and port smother to help with the air flow and round the mdf in port begining and end
any suggestions?
Port Width 3"
Port Height 15.7"
Port Length 31"
any suggestions?
u still got the 1k amp? someone have to model it for correct port size.. your last box was 1.9 cf per sub right? should be able to do about 3.5cf ad with slot port in same space..
3cf is too small for those, go up to 4-4.5cf
alpine recomended for these 1.3cf for each sub so 2.6cf after sub and port displacement
im going a bit bigger giving 1.5 cf for each sub 3cf total after sub and port displacement
these type r are the 500rms not the new 750 rms or 1000rms one´s i wish they was :p
yes crossfire down to 1 ohm... it puts out more than 1k....
last ported box was about that 1.9cf per chamber but for 2 pioneer the recomended for those is 1.65cf and i made those a bit bigger like im goin to do now... going from 1.3 recomended to 1.5cf, its nice rigth?
i put some data on winsd nd it tell me that i will have this curve (Green line)
what do u guys think about this curve? is bad, nice or good :p
it's good but if u tune high u get bigger bump around 40hz (if u tune to like 36hz) that crossfire has ss filter i can't remember? if so tune high be tad louder but if u like real low bass and play rap stick ti 34hz.. check rear port air velocity set system power at like 700 watts, make sure air is no more than 30 mps with slot port..
You got too much port area too small of an enclosure... it wont go low well imho
i was playing around with some port tunes (30 to 40) and 34hz was the most balanced one to me...
yes it have ss filtre i was thinking about setting the ss to 30hz
how do i calculate the port speed?
this is not scale is just for u guys to get the whats in my head :p
dark brown - port space
light brown - 3cf box space
red - 2in round pole for bracing, probably 3 all in line, top midle and base...
blue conners - 1/4 pvc pipe
green space - spare space matched for subs bracing and "conners" displacement
and yes the green space was planed to above 3 cf i dont want the displacement to still from the 3cf, by my math at the end i will get like 3.05cf after all the displacement
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
You have roughly 50 liters total, which will probably work with that sub.
Portugal (europe)
shredder2
    May 16, 2024
    May 16, 2024
