is this 150 RMS @ 4 ohms by any chanceThe new line of Linear Power amps will be available this spring. They are still designed and built in the USA, and are of even better SQ and quality than our old units. We will be introducing three two channel amps in the beginning, the LP2075 (75x2RMS), LP2150(150x2RMS), and LP2250(250x2RMS). They will be rated at 12.8 volts at 100 hz, not the 14.4 volts at 1Khz rating the other SQ companies are using to get higher power figures, even though we will give power figures at those rating for comparison. We will be supplying more data on the units shortly.
Dimensions on the new amp line:
H = all amps will be 2.375"
W = all amps will be 9.25" (main body) 10.4" counting mounting feet
L = LP2075 8", LP2150 9.25", LP2250 14.5"
Yes (4 ohms) ... (150 RMS) and then some ...is this 150 RMS @ 4 ohms by any chance
thats the plan ...hopefully they will last just as long as that purple 652 i haz since 1992
how much will the 250RMS @ 4 ohms, price be?The new line of Linear Power amps will be available this spring. They are still designed and built in the USA, and are of even better SQ and quality than our old units. We will be introducing three two channel amps in the beginning, the LP2075 (75x2RMS), LP2150(150x2RMS), and LP2250(250x2RMS). They will be rated at 12.8 volts at 100 hz, not the 14.4 volts at 1Khz rating the other SQ companies are using to get higher power figures, even though we will give power figures at those rating for comparison. We will be supplying more data on the units shortly.
I think he answered this question in this post ...how much will the 250RMS @ 4 ohms, price be?
They will not be cheap, but compared to the other SQ brands such as Zapco, Audison, Focal, Tru Technology, Mosconi and the such we come in several hundred dollars cheaper. We do not have the exact prices yet, but the really near ballpark is going to be
LP2075 (75x2 RMS @ 12.8 at 100 HZ or less) 900-1000.00
LP2150 (150x2 RMS same conditions 1200-1300.00
LP2250 (250x2 RMS same conditions 1800-1900.00
One thing you have to remember is that our pwoer ratings are at 12.8 at 100 HZ or less, all the brands I listed are at 14.4 volts at 1Khz. So our power output is SIGNIFICANTLY higher if we rate them like the other brands at 14.4.
Example the LP2150 is rated for 150x2 at 12.8, at 14.4 it makes a minimum of 195 watts a channel RMS. Comparing power versus price the Zapco 150x2 is 1499.00 retail, and the BASE True Technology 110x2 (they don't make a 150x2) is 1599.00 and if you want the SQ stage 4 upgrades (almost all the parts that you get with our STANDARD production unit) the price jumps to 2699.00 for the Tru Technology piece. We are going to be well hated by these companies when word gets out about a really TRUE SQ line of amps we have.
Yep they are pricey...**** 2000 for amp?
i guess this is for PRO/competition set up's only
i dont know who in their right mind would spend that much on a daily
Example the LP2150 is rated for 150x2 at 12.8, at 14.4 it makes a minimum of 195 watts a channel RMS. Comparing power versus price the Zapco 150x2 is 1499.00 retail, and the BASE True Technology 110x2 (they don't make a 150x2) is 1599.00 and if you want the SQ stage 4 upgrades (almost all the parts that you get with our STANDARD production unit) the price jumps to 2699.00 for the Tru Technology piece. We are going to be well hated by these companies when word gets out about a really TRUE SQ line of amps we have.**** 2000 for amp?
These are pics of the mock up of the fan shroud, this IS NOT the fan shroud. This is heavy cardstock to get the dimensional fit to scale the machine drawings from to produce the metal shroud. This was a functioning mock up that actually was used to test the air flow, as well as get ideas how it would look. The production units will be colored to match the sinks and have art work and lettering on them.
