Linear Power and Blues Car Audio at SBN 2012
We have been selling the speakers for almost 2 years now. We list max MSRP on our site, Blues Car Audio , and give the dealers a MSRP window to sell them in. We only sell direct from our site at max MSRP and we give our dealers a protected area by US Postal Service Zip Code, and we will not sell directly to anyone in those areas. In these areas we refer any potential customer to the dealer in their area.
The amplifiers will be sold in the same way. We do not allow any internet sales from any outside source, only factory direct sells are allowed, again only in non-protected areas without any dealers. We do have a promotional program for different areas of the country where we have not sold products in yet. In these areas we will give a promotional discount to one individual per area in a one time purchase. This promotion is to have someone in the area that will hopefully demonstrate the product to others in the area. This program dissappears once we have one individual using the products, we have established a dealer in that area, or we have hired a sales rep firm to promote the product and select dealers in the area.
We make efficient SQ woofers and speaker comonent systems, and only currently offer 6.5, 8, 10 inch woofers in 4 or 8 ohm versions, and 8 inch Iso-Kit 8 and 10 inch Iso-Kit 10's in 4 ohm versions.
We have 5 two way component sets, which consist of
BL5.2CP, 5.25 inch passive two way component set with an Fs of 68 Hz and a power handling of 100 watts RMS per channel
BL6.5CP, 6.5 inch passive two way component set with an Fs of 36 Hz and a power handling of 175 watts RMS per channel
BL6.5CA, 6.5 inch active two way component set with an Fs of 36 Hz and a power handling of 175 watts RMS per channel
BL8.0CP, 8 inch passive two way component set with an Fs of 29 Hz and a power handling of 175 watts RMS per channel
BL8.0CA, 8 inch active two way component set with an Fs of 29 Hz and a power handling of 175 watts RMS per channel
The component systems use driver compensation circuitry on both the mid/woofer and tweeter to give a very smooth impedance curve thru the audio bandwidth that drives the amplifier to make even power across the bandwidth and provides very clean and proportionate midrange and keeps the system phase angle flat on zero degrees (+/- only 5 degrees) from the low freq. roll off of the woofer to over 45 kHz. The mid/woofers are not crossover on top or bottom end and the tweeters are crossed over at 12 dB per octave at 2500 Hz and also have tweeter protection.
We will have 4 inch driver (BL4.0-4) shortly and it's power handling will also be 100 watts RMS and uses the same motor assembly as the 5.25 (BL5.2-4)
Spring Break Nationals is getting close !!!
Please make sure to swing by the Linear Power / Blues Car Audio booth and check out the new products !!!
We plan to have demo vehicles (one being mine "White Lightning") and competition vheicles to check out and Demo ...
Hope to see you there !!!
linearpower
linearpower
pearl ms
cablguy184
