New hdc4 12s box ..with octo!!
Box is looking good. Curious as to why port is touching bottom of the box vs centered? In theory that would extend port length some....
My inefficient slot port box did a 52.4 with a single 3500 the other day, so I expect big numbers from this //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
I should squeeze that out even if i gota wire to .25 and roll up ...idk the design was done by dcarcustoms on maf
You can see from his max box width if the port rises it will weaken the support around the sub to keep the 8.6 port they lowered it t the floor. Your right though any round type port is supposed to be spaced equally around its dia. to fully function as intended. It will not function as efficiently but I suspect they had to make the best of the design limitations.
Yea had to sacrifice a few inches off center as i didnt want to cut down on port area ..i suspect it to turn out well tho
NASTY08IMPALA
NASTY08IMPALA
LOUISVILLE, KENTUCKY
NASTY08IMPALA
