Need to Know About Wiring
  • 2
Not sure of the specific location, but there will typically be a location where a bundle or even just a few wires are running thru from the engine to the firewall. I normally use a coat hanger straightened out to push thru gently(don't hurt the wires) and then use that as a guide to feed my power wire thru and into the cab. Hope this helps u out.
401
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
523
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
LBX2G
R.I.P Camofluage
LBX2G
Warner Robins
LBX2G
    May 22, 2024
    May 22, 2024
