Need to crossover to high pass
Rustyd2k2
4
ga
Ok, I need help from you guys because i am having a really hard time with this, any help would be apprichiated. I have a MA Audio Hk1997 amp(which is 1ch mono 1200w) and i am pushing a pioneer premier ts-w2000spl. The amp olny has LPF and Full crossovers. And i want the boom so im looking for the Highs crossover. Can i buy a crossover and hook it up to the mono amp and be ok? Or is it more complicated than that???
Thanks guys
Thanks guys
What? Are you running your highs and mids off the headunit? If so go passive. The amp you have is mono...for sub. I guess I'm not to sure what you want. Your MA has nothing to do with the highs and mids...LP for sub only. You shouldn't be running any highs and mids off this amp. Explain your setup a little more.
If you are running that amp to a sub, you WANT to use the low pass filter/crossover. A low pass filter cuts off frequencies above whatever frequency you set it to, so your sub can't play higher frequencies that can cause damage. Think about it like this, high pass cuts off lows, and low pass cuts off highs. You have what you need on that amp. I have mine set to about 80 hertz. That way, the sub cannot play any frequencies above 80 hertz. It will play anything below that. I hope that answers your question and solves your problem.
Rustyd2k2
Rustyd2k2
ga
EzekialPhoenix
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
