Need sub help
I feel there is more to the story than just changing the batteries. Did you remove RCA cables? Did you move the head unit? Did you move the amplifiers? Try your fader... does the bass get less going front to rear or rear to front or left to right? If there is any change in the subs... check where your RCA's are connected.
Yes the base is less if I use fader to only the front speakers
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
DKenworth
DKenworth
Iowa
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
